STARTECH ICUSB232DB25 USB TO SERIAL ADAPTER - 3 FT. - 1M - WITH DB9 TO DB25 PIN ADAPTER - PROLIFIC PL-2303 - USB TO RS232 ADAPTER CABLE
StarTech ICUSB232DB25 USB to Serial Adapter - 3 ft. / 1m - with DB9 to DB25 Pin Adapter - Prolific PL-2303 - USB to RS232 Adapter Cable Type: Data Transfer Cable Type: Cable Connectors Color: Black Connector Number: 2 Connector Detail: External Ports: 1 - DB-25 (25 pin; D-Sub) Male External Ports: 1 - DB-9 (9 pin; D-Sub) Male Specifications: Interface: USB 2.0 Ports: 1 Product Weight: 2.47 oz [70 g] Serial Protocol: RS-232 Maximum Data Transfer Rate: 250 Kbps Data Bits: 4, 5, 6, 7, 8 Stop Bits: 1, 1.5, 2 FIFO: 512-byte bi-directional buffer Parity: None, Even, Odd, Mark, Space Flow Control: None, Xon/ Xoff, Hardware Bus Type: USB 2.0 Connector Type(s): 1-USB A (4 pin) Male Humidity: 0~90% RH Operating Temperature: 0ºC to 60ºC (32ºF to 140ºF) Storage Temperature: -20ºC to 80ºC (-4ºF to 176ºF) Chipset ID: Prolific-PL2303HXD Microsoft WHQL Certified: Yes OS Compatibility: Windows 2000/ XP(32/64bit)/ Server 2003(32/64bit)/ Vista(32/64bit)...
Price: 15.79
