STARTECH ICUSB232V2 USB TO SERIAL ADAPTER - PROLIFIC PL-2303 - 1 PORT - DB9 - 9-PIN - USB TO RS232 ADAPTER CABLE - USB SERIAL
StarTech ICUSB232V2 USB to Serial Adapter - Prolific PL-2303 - 1 port - DB9 (9-pin) - USB to RS232 Adapter Cable - USB Serial Type: Data Transfer Cable Type: Cable Connectors Color: Black Connector Number: 2 Connector Detail: Connector A: USB A (4 pin) Male Connector B: DB-9 (9 pin; D-Sub) Male Specifications: Bus Type: USB 2.0 Chipset ID: Prolific - PL2303-HXD Industry Standards: USB 1.1/2.0, RS232 Interface: Serial Port Style: Cable Adapter Ports: 1 Data Bits: 5, 6, 7, 8 FIFO: 512 Bytes Flow Control: None, Xon/Xoff, RTS/CTS, DTR/DSR Max Baud Rate: 921.6 Kbps Parity: Odd, Even, Mark, Ace, or None Parity Modes Serial Protocol: RS-232 Stop Bits: 1, 1.5, 2 Microsoft WHQL Certified: Yes OS Compatibility: Windows 8 (32/64bit), 7 (32/64), Vista(32/64), XP(32/64), 2000 Windows Server 2012, 2008 R2, 2008, 2003(32/64) Mac OS 10.x (Tested up to 10.8), 9.x, 8.x Linux kernel 2.4.31 and later Electrical Outlet Plug Type: Plug Type “A�...
Price: 13.67
